Group: DynoMotion Message: 405 From: Azd M Date: 6/4/2010
Subject: Max. Following Error Handler
Hi all,
I am using Kflop+Kanalog to control robot axis with break. I want to break the system in case of Max following error is detected otherwise the axis will be disabled and the it will fall down.
the break is controlled by one of the FET switches on the Kanalog.
Is there any options for this event similar to Limit Switch options?
Azeddien
Group: DynoMotion Message: 407 From: Tom Kerekes Date: 6/5/2010
Subject: Re: Max. Following Error Handler
Hi Azeddien,
There is no provision for this but you should be able to do it with a "watchdog" type of User C program that runs constantly and watches if anything bad happens and applies the brakes.  Something like:
    for (;;)  //loop forever
          WaitNextTimeSlice();
          if (ch0->Enable)
              SetBit(152);
              ClearBit(152);
Group: DynoMotion Message: 410 From: Azd Md Date: 6/5/2010
Thanks Tom,
By the way How can share variables with other running threads?
Azeddien
--- On Sat, 5/6/10, Tom Kerekes <tk@...> wrote:
Subject: Re: [DynoMotion] Max. Following Error Handler
Date: Saturday, 5 June, 2010, 11:32 PM
Hi Azeddien,
#include "KMotionDef. h"
          WaitNextTimeSlice( );
          if (ch0->Enable)
              SetBit(152);
              ClearBit(152) ;
Group: DynoMotion Message: 411 From: Tom Kerekes Date: 6/5/2010
Hi Azeddien,
There are 100 global 32 bit variables called persist.UserData[100].
(They are called persist because they are in an area that gets flashed if you flash user programs).
You can communicate between threads using these variables.  If you need more, declare an array or structure in one thread and pass the address of the object to the other thread through a UserData variable.
Group: DynoMotion Message: 413 From: Azd Md Date: 6/5/2010
What do u mean by flashing a user program?
regards
Date: Sunday, 6 June, 2010, 1:15 PM
Hi Azeddien,
There are 100 global 32 bit variables called persist.UserData[ 100].
Group: DynoMotion Message: 414 From: Tom Kerekes Date: 6/5/2010
There is a button on the Config/Flash Screen called "User Memory".  It saves all the configuration variables, User programs, and persist variables to flash memory.  This allows KFlop to run in "stand alone mode" (No PC connection).  Where it can run a User program immediately on power up.  But if you are using a PC to control things, it isn't necessary or recommended to use this.  It's simpler to just download from the PC when your program initializes.  That way the board remains in the default state and you don't get confused with what configuration or source was flased into a particular board.
